Are there tools in Vensim that analyses
sensitivity analysis using either SWAT-CUP (SWAT calibration uncertainty procedure)
and SUFI-2 (Sequential uncertainty fitting ver 2)
or include "P factor" and "R factor" ?
R factors is the ration of the average 95PPu band and the SD of measured variables
P factor is the fraction of measured data bracketing by 95PPU band.
95PPU (95% predictive uncertainty )
Re: sensitivity analysis
I've never heard of SWAT-CUP or SUFI-2. Tom might have though (I'm sure he'll be online later). But the words "calibration" and "fitting" suggest these are optimization procedures, not sensitivity.
Can you calculate these R and P factors in your model and use them in your analysis?
I hadn't either, but I assume it refers to this: https://swat.tamu.edu/media/114860/user ... watcup.pdf I'd probably have to go back to the source papers to find out what's really going on, but this discusses parameter ranges as if the problem were univariate.
A key benefit of MCMC is that it generates a sample representing the joint, multivariate distribution of parameters. That makes talking about univariate bounds (especially uniform univariate bounds) on parameters a little unnatural.
The corresponding procedure in Vensim would be to use MCMC to generate a sample of points, then use the sample to generate sensitivity runs using the sample as file input.
Hi Tom,
I just exported sensitivity analysis results and I got columns with a prefix like "T1" until "T24".
What does it mean?
Which ones are low percentile, median and high percentile?
What does it mean?
The T values are times, which you get when you choose to modify names by time http://vensim.com/documentation/ref_dat ... _sensi.htm
Percentiles are only available in command scripts: http://vensim.com/documentation/sens2file.htm
