Respected Tom
in the context of simulation models there will be a warmup period (Time) like this in vensim also is there any warmup time. if it is there how can we use that?
is there any function to follow the Weibull distribution?
warm-up period
Re: warm-up period
Can you give a little more information on what you mean by "warm up time"?
And have you searched the documentation/help system for the Weibull distribution?
Re: warm-up period
The warm-up time is the time that the simulation will run before starting to collect results.
I have gone through the help manual regarding Weibull distribution. I got it. thank you, sir
Re: warm-up period
Vensim will not do this for you, it's up to you to implement it (or not, depending on the problem you are trying to solve).neelu@nitw.ac.in wrote: ↑Wed Jul 25, 2018 11:49 am The warm-up time is the time that the simulation will run before starting to collect results.
Re: warm-up period
You can also use the "Resume" functionality to restart runs after a warmup run.
Re: warm-up period
