Does Vensim do a similar process/steps to calibrate a stock and a flow variable?
Shall I am aware something when I calibrate either a stock/flow variable?
optimize-calibration
Re: optimize-calibration
Sorry, I do not understand what you want to do.
Have you looked at the help system for calibration?
There's no difference, except with respect to Kalman Filtering. https://www.vensim.com/documentation/ref_kalman.htm
Tom, thanks a lot for your reply.
If we do calibration continuously (maybe 24 hours), does it mean we will get
almost nil payoff?
or
does Vensim absolutely help us to get almost nil payoff?
Could you please explain of how to create Kalman-filter file (*.prm)?
almost nil payoff?
or
It depends on the model you are trying to calibrate. Large models might never calibrate fully.
Have you checked the Vensim help system?
http://www.vensim.com/documentation/ind ... ?23625.htm
I am trying to calibrate a stock model (fluctuated values depend on precipitation) and
I have found it's hard to get fully calibrate.
The model itself contains only less than 35 variables.
35 parameters, or 35 variables in total?
If the model doesn't fit the data after you've extensively explored the parameter space, there are some generic possibilities:
- model structure is wrong or incomplete somehow
- data has systematic errors
- noise has moved the system state
Hi Tom,
after applying Kalman filter, I got a better position.
Thanks.
Thanks.
