How does sensitivity analysis work on subscripted variable. The sensitivity Simulation setup does not seem to allow you to select the individual subscripts to apply and tries to assign a single value that fails. From the VSC file on a single subscripted variable:
200,M,1234,,0
SubscriptedVariable =RANDOM_UNIFORM(.1,.9)
Would editing the VSC file to account for individual subscript groups work? The documentation of simulation and subscripting do not seem to overlap. Any guidance would be appreciated.
Thanks You
Eric
Sensitivity on subscripted variable
Re: Sensitivity on subscripted variable
When you select a parameter, the variable list dialog has an option to add the subscript range or elements. Alternately, you can add it manually in the parameter field in the sensitivity control setup dialog.
You can also edit the .vsc directly, but that's generally not needed.
This won't work. You either need SubscriptedVariable[range] or SubscriptedVariable[element].SubscriptedVariable =RANDOM_UNIFORM(.1,.9)
