Sensitivity graph's Vertical Axis setting
yut
Post by yut »
Hi there,
I would like to specify the maximum and minimum of the vertical axis of sensitivity graphs.
Could anyone give me how to set it?
In my case, Sensitivity Graph's default setting is that maximum is 500, but I would like to set it to 500.
Thanks in advance.
Re: Sensitivity graph's Vertical Axis setting
You can control that with a Custom Graph: https://www.vensim.com/documentation/23995.htm
A custom graph is basically a normal graph with the :CONFIDENCE keyword added to provide confidence bounds. https://www.vensim.com/documentation/24000.htm
yut
Post by yut »
Hi Tom,
Thanks so much!
I succeeded in it.
