Vensim unit check
miloud94
Vensim unit check
Post by miloud94 »
I am currently fixing unit errors from my model and especially when I use lookup functions I do not know how to fix the unit errors. I read the guide on vensim about units checking (https://www.vensim.com/documentation/in ... ?22280.htm). It does not make sense for me to introduce another variable that will fix the unit errror by making it dimensionless (according to the guide).
Do you have any other suggestion how to fix my unit problem especially for lookups ?
lookup unit.PNG (23.63 KiB) Viewed 1543 times
Unit problem.mdl
(28 KiB) Downloaded 172 times
Re: Vensim unit check
In this case, you can ignore the warning (it's warning rather than error).
It's on my list of things to do to improve (or remove) the warnings for dimensioned lookups.
