this message blocks resuming the simulation, how can disable this message?
Dataset current already exists. do you want overwrite it?
- komunikat.png (143.62 KiB) Viewed 2433 times
Re: Dataset current already exists. do you want overwrite it?
Click yes and it will simulate OK.
But I don't want this message to be displayed at all.
I would like to disable this message permanently.
Thank you.
Thank you.
It won't appear if you change the run name each time. You can disable it in command scripts with the NOINTERACTION command.
Thank you very much.
