I'm trying to export data from vensim to excel, however, I have a series of 420491 data and I'm only managing to export up to 65534. Do you have any export restrictions on vensim? Is there any solution for me to be able to export all the data?
Export
Re: Export
I think that's an Excel column limitation, not a Vensim limit.
Try switching to tab-delimited or csv, or switch time from down to across if you have more variables than times.
You can use a savelist and data export interval (or saveper) to restrict the size of the dataset.
