As you know, the address of external function in Vensim is in C:\Users\Public\Vensim\cfiles\venext.dll. But in this folder all files are in machine code. I want to change some part of my external functions but I cannot access their C format in this folder? Do you know which file has to be changed for updating external function?
How to change external function
Re: How to change external function
Do you already have an external function library? If yes, you must have edited the C code in the past to create the DLL.
If not, the latest version of Vensim ships with a sample Microsoft Visual Studio workspace to create the DLL. You will find it in
C:\Users\Public\Vensim\COMP\VensimExternalFunctionLibrary
Administrator wrote: ↑Wed Feb 20, 2019 10:46 am Do you already have an external function library?
I have one 'venext.lib' in this folder( C:\Users\Public\Vensim\cfiles). My model already has its own external function and it works well. I just want to know how can I edit one of these external functions.
Does it mean that I cannot edit it now?
What I have to clarify is that, I want to edit one of user defined functions. The thing is that, I do not find its C cource in COMP path(C:\Users\Public\Vensim\COMP) or cfiles path(C:\Users\Public\Vensim\cfiles), although I just see its .obj foramt in cfiles path.
Users\public\vensim\cfiles isn't part of the Vensim distribution - could you have received that from whoever wrote the code for the external function?
Yes, your are right. This folder has been added to Vensim folder and I want to edit its external fucntion which are all in '.obj' format. Can I add all those external function in venext.c file?
You'll need the .c source code for the functions you're using.
