Hi, Guys
I do not have the DSS version of vensim. I only have the PLE version.
I need to put a historical series of data, so I know that with my version I can not import the data.
I'll do this by creating a LOOKUP variable, defined as a function of the <time> variable, then doing the time series input in the LOOKUP variable dialog box.
My question is: Are there restrictions on the size of the historical data series in the LOOKUP variable?
Thanks,
LOOKUP
Re: LOOKUP
The only restriction is the amount of text you can fit into the equation editor. Try and enter the data and see if it works.
