I'm following the tutorial from SDEverywhere on how to get a Vensim model onto the web.
I've got as far as installing Emscripten. But the tutorial says to run "emcc -v" to test it's installed properly. I get "command not found".
Is there another way to test Emscripten is installed properly?
Thanks in advance,
SD Everywhere Emscripten issue.
Re: SD Everywhere Emscripten issue.
ok, managed to figure this out. I was running
from the terminal window rather than
Running "emcc -v" now gives me output.
./emsdk_env.sh
source ./emsdk_env.sh
