We run several models on a Unix server using the Vensim DLL and, up to now, we haven't had any serious problems, but we can't get our latest model to run at all.
We're using Vensim(r) DLL(Multicontext/Silent) version 6.4d Double Precision running in Java. When we load the model file - it loads OK, but the next command "MENU>GAME" fails for some reason (see the attached image)
There's no log to record what is happening, so we're stuck at this point. It works OK on Windows with the Windows DLL "Vensim MultiContext Silent DLL Version 6.4d".
We did have a problem a short while ago with this model, after we produced it and published the VPM file from Vensim 8. We then loaded the MDL file into Vensim 7 and published the VPM from there and it seemed to be OK. Could this be an issue related to those version problems?
Phill
DLL error
Re: DLL error
In case it helps, all the commands prior to MENU>GAME are executed properly, only MENU>GAME fails.
- DLLerror2.png (42.08 KiB) Viewed 1460 times
Re: DLL error
Can you email us directly regarding this please?
