I use Vensim DSS version 4, OS: Win ME
when load information from Excel I get the following error
Range (or named range) R1C4:R1C253 in file PUB Input.xls (sheet Vensim-Variabelen) incorrect or noncontiguous.
ERROR: Failed to make live links to data - aborting simulation.
ERROR: Unable to correctly load in exogenous values - aborting.
I reinstalled the software but that did not help.
I am a employee of IBM, former PwC, and the software I use is a PwC licence, could that couse trouble?
The link used to work properly, nothing changed as far as I know.
Regards, Robert
error
This can be caused by one or two things. The most obvious one that springs to mind is that maybe the operating system changed from English to another lanuage recently? In this case, the R1C1 convention that Vensim uses may not be appropriate (as they might not be called Rows or Columns). If this is the case, look in Vensim, go to Tools->Options->Settings, near the top right of the dialog there is an Excel R1C1 settings box. Change these to what ever letters are needed.
Can you let me know if this is the solution?
answer to R1C1 error
Thank you both for your answers.
I changed C into K(olom) (R1C1 now is R1K1) and the Get XLS data funtion works!
