Warning: "Can load at most 16 runs at one time"???
Simplifier
Post by Simplifier »
I'm running the simulation for my model and I get this warning: "Can load at most 16 runs at one time".
What does it mean and how to fix it?
Re: Warning: "Can load at most 16 runs at one time"???
It means you can only have 16 runs loaded for viewing at once. Go to the Dataset tab of the Control Panel and unload a few, or just ignore the warning.
Simplifier
tomfid wrote: Sat Feb 08, 2020 1:35 am It means you can only have 16 runs loaded for viewing at once. Go to the Dataset tab of the Control Panel and unload a few, or just ignore the warning.
Oh thanks very much!!!
Simplifier
I also have another question. When I run simulation for my model, on the simulation run window it for instance announces "Simulation 3,000; 37 errors". Where can I find every single error in the components of my model in order to address and fix them?
Model>Check Model will open into the equation editor, with all the structural issues in the error menu at the bottom.
Typically most are usage - variables that are unusued. You can suppress those by checking the Supplementary box if non-use is intentional.
The rest of the errors appear at runtime. Be sure that Display Warnings is selected in Tool>Options>Settings.
