I need help in simulating a model. I have data uploaded for some variables while other variables have equations (they don't have data).
I only receive errors when trying to simulate. I will appreciate some help.
Simulating a model with uploaded data and some variables with equations
- Vensim version: PLE
- Model- Australia.mdl
- (6.23 KiB) Downloaded 162 times
- AustraliaData.dat.xls
- (29 KiB) Downloaded 139 times
Re: Simulating a model with uploaded data and some variables with equations
You cannot use external data if you are only using PLE.
However, you can put the data in a lookup as a workaround.
Thanks for your reply. Can you give me directions on how to put the external data in a lookup as a workaround? Sorry, but I'm still very new to Vensim, so it's a bit challenging. Thanks!
