Persistent Lookup Plots
rob_n
Post by rob_n »
I'd like to make a Vensim view that shows graphs of all the lookup tables in a model. Ideally this would be a custom graph, so if I edit the lookup table then I can see the changes.
I can hack this as follows: dummy output = LUT(dummy input), then make a custom plot of dummy output using dummy input as the X variable.
For one lookup table this isn't so bad, but becomes tedious when there are several. Is there a better way to do this?
Best regards,
Rob
Re: Persistent Lookup Plots
That's the only way I can think of to do it. You can edit the custom graph file in a text editor to speed up the graph definitions.
What do the lookups contain? Is it data over time?
