custom sensititity histograms
apm
Post by apm »
Is it possible to create custom sensitivity histograms in .vgd files? I'm got different sensitivity histograms that are best displayed with different numbers of bars, and bounds, so I'd like to create custom histograms that I can then place on the interface. Is this possible? Thanks!
Re: custom sensititity histograms
It should be, but looking at the docs, it's not in the language.
https://www.vensim.com/documentation/24010.htm
Will investigate further and put it on the todo list.
apm
Post by apm »
I just wanted to check that this update did not make it into 8.1. I did not see it, but thought I'd check to make sure.
