Now when i try to compile with the 32 version it says 'failed to compile the model (version mismatch got 52050 need 51050).
problem when trying to compile with the 32 version
Re: problem when trying to compile with the 32 version
Are you trying to compile with an older version of Vensim?
with the 7.3.5 single precision.
ok. If you want to keep 7.3.5 and 8 of Vensim you also need to have two separate COMP folders. The compiler has different settings for 7.3.5 and 8.
The only reason of wanting to keep the 7.3.5 version is if there is by lack of chance something critical not working with the 64 version. Otherwise I have no reason to keep the old version, especially as you can run the old models without any change. I will wait a bit before building a different comp.
