I'm using the python Exploratory Modelling & Analysis workbench here: https://emaworkbench.readthedocs.io/en/ ... index.html
However, it cannot find the Vensim .dll files when I try importing the connector. I get the following error:
When I go to the vensimDLLwrapper.py file, which generated the error, and the comment at the top says:ImportError: vensim dll not found
I have looked in System32, SysWOW64, AppData/Local and AppData/Roaming/Vensim, and I can't find the vensim DLL anywhere.by default it is assumed the dll is readily available. If this generates an
VensimError, you have to find the location of the dll and either copy it to
C:\Windows\System32 and/or C:\Windows\SysWOW64, or use::
vensim = ctypes.windll.LoadLibrary('location of dll')
Typically, the dll can be found in ../AppData/Local/Vensim/vendll32.dll
