Greetings!
I did not find the following in the forum:
Is it possible to import anylogic 7 SD models into Vensim?
Anylogic 7 allows the importation of SD Vensim models not sure why if it can go the other way - from = Anylogic to Vensim.
Thank you.
Kinds regards,
Lening
Importing Anylogic 7 Model to Vensim
- Vensim version: PRO
Re: Importing Anylogic 7 Model to Vensim
I've never seen the raw code for an Anylogic model, but if there's a text version, it might be possible without much effort. If it's not text, or not pure SD, it might be hard - probably easier to replicate by hand, possibly in Ventity if there are agent features in use.
Thank you. I'll look into ventity and download the software as I have not done so.
