Change view from text view to skecth view
husnafezaahmad
Post by husnafezaahmad »
Hello mates,
I have one question.
How can i change the layout of my model from text to sketch view?
Tried to do it through the VIEW tab, but still couldn't get it into sketch view.
Re: Change view from text view to skecth view
Do you get a syntax error when you try to switch? If yes, what is it? Or can you upload the model or show us where the error is?
husnafezaahmad
Administrator wrote: Wed Sep 09, 2020 12:40 pm Do you get a syntax error when you try to switch? If yes, what is it? Or can you upload the model or show us where the error is?
Yes....i do get a syntax error.
I'm afraid i can share this model because it's not mine. But the syntax error written is "missing a closin paranthesis on a lookup table call".
And it happened that the cursor is at this part of the model
Pink Noise Maker=
RANDOM PINK NOISE( 1, 0.1, 1, 1234 )
~ Dmnl
That looks fine to me. Do you have RANDOM PINK NOISE defined as a macro?
What parameter follows this one in your Vensim file? Maybe the syntax error is with the next variable.
