Is it possible to represent graphs with with no lines or with horizontal lines only?
I have set according to the figure setting.png and got the result as graph.png.
It was required to keep runs numbered as well.
Many thanks,
Daniel!
Graph help.
Re: Graph help.
I'm not sure what you are asking for. The graph will show the results in the simulation, Vensim will not show a straight line if the results are not constant.
Re: Graph help.
Is it possible to hide all the vertical gray lines?
Re: Graph help.
Not at the moment. It looks like you've found a bug, I'll experiment to see if I can fix it as there should be a way of removing the lines.
Re: Graph help.
Right click on the graph tool, and you will find a setting titled "X-Divisions". Select the "As global" option, and now your graphs should be missing the lines.
Re: Graph help.
Yes, it now works! Great, thanks!
