I'm having the following problem
khaldrogo
Newbie
Post by khaldrogo »
I have a data set (vdf-file) that I want to use for 3 data variables. The data loads correctly into 3 data variables (highlighted in red in the attached model). However, as soon as I tried to run the test, I got the following error.
"Variables- DATA Installation Speed -and perhaps other variables require a data file specified."
I know that I cannot specify the data file in Vensim PLE, however, the data loads correctly into the variables. Is there any way to help me?
Thank you so much!
Re: I'm having the following problem
PLE does not support external data.
You could put the numbers into lookup tables if there is not a large amount of data.
Another option, if the data is for comparison, is to use the Reference Mode tool.
