Hi, trying to run a sensitivity run I ran into a savelist dialog box looking like this - see attached savelstis.png
whereas the documentation shows it should look like this - see attached savelstdoc.png.
I am using 8.2.1. PRO, what am I doing wrong?
Thanks and best,
Ulrich
Savelist dialog in 8.2.1. does not work
- savelstdoc.png (50.37 KiB) Viewed 1423 times
- savelstis.png (72.16 KiB) Viewed 1423 times
Re: Savelist dialog in 8.2.1. does not work
You may be in the legacy graphics mode. Try
Tools>Switch to New Sketch or Switch Back to Old Sketch
The documentation will catch up to the new interface over the next few minor releases.
Also, v9 is now available.
Thanks for pointing out the error in the help system.
In the new savelist editor, just click to select the parameters you wish to save.
