DELAY1
jie
DELAY1
Post by jie »
I would like to ask about the delay1 function. If the image produced by this function is the translation of the image, the maximum and minimum values are consistent? The maximum and minimum values of the image I got using this function in the model are inconsistent with those before the delay. I would like to ask what the image generated after using the delay1 function should look like?
Re: DELAY1
I'm not sure I understand what you are asking for.
Have you looked at the sample model showing how the DELAY functions work?
jie
Re: DELAY1
Post by jie »
In fact, I want to know what the image produced after using the DELAY1 function is?
Re: DELAY1
It's not a pipeline or infinite-order delay. It's a first-order exponential delay. The output is not an image of the input. See the sample models in the Help system, or https://metasd.com/2011/04/delay-sandbox/
If you want a pipeline delay, there are several options, starting with DELAY FIXED.
