In my model I have a variable depending on a lookup coefficient. As the time passes the coefficient either reduces or increases so does the variable. How can I set the variable to stay constant if the new value for the coefficient is lower than the previous one?
Functions
Re: Functions
I don't understand what you are explaining. But I'll have a guess.
You can use the SAMPLE IF TRUE function to keep the value. For example
my value = sample if true ( coefficient > my value , coefficient, coefficient )
This will only increase "my value" if coefficient is greater than the last value for "my value".
