Stocks and flows
jensen568
Stocks and flows
Post by jensen568 »
Hey, im new to vensim. I cant seem to figure out how to make this stock and flow diagram work..
I would really appreciate som tips/help! :D
Tommis s and f.mdl
(6.82 KiB) Downloaded 138 times
Re: Stocks and flows
I think it would be good to start by resolving the unit errors, because some of them suggest conceptual problems in a few equations.
In particular,
Surveys in execution  =
        INTEG( ( surveys in executions
                  + Surveys executed )
                  / 2,
             100)
I'm not sure what's going on here, but this is integrating the average of the inflow and outflow, both as positive values. Probably this should just be INTEG( surveys in executions - Surveys executed, 100 ). Generally your INTEG expression (i.e. stocks) should only be summing the inflows (added) & outflows (subtracted).
Cancelled  =
        Surveys in aqusition
             * ( 1
                  - 0.8)
Not sure what the "1-0.8" here means, but guessing that this should be made a separate named parameter, like
cancellation rate = 0.2 ~ fraction/year There are several other parameters buried in equations that should be made into separate named variables.
jensen568
Post by jensen568 »
Thank you for you're reply! :D
