Simultaneous equations involving: (array element)
rob_n
Post by rob_n »
I'm trying to do some feedback-like math in an array dimension. Using subscript mapping it is straightforward to calculate the accumulation of an array. But when I try to do something like a first-order exponential smoothing I get a “Simultaneous equations” error.
Two similar blocks of code: Block A works, Block B does not. What am I missing?! Full simulations are attached
Best regards,
Rob
.common code
horizon:
(h1-h5)
horizon earlier:
(h1-h4) -> horizon later
horizon later:
(h2-h5) -> horizon earlier
h interval==
1
~Week~|
Signal=
1
~unit/Week~|
Array Signal[horizon]=
Signal
~unit/Week~|
.Block A code WORKS:
Cumulative Signal[h1]=
0 ~~|
Cumulative Signal[horizon later]=
Array Signal[horizon later]*h interval+Cumulative Signal[horizon earlier]
~unit~|
.Block B code DOES NOT work; “Simultaneous equations involving: Average Array Signal [h2]"
Average Array Signal[h1]=
0 ~~|
Average Array Signal[horizon later]=
Average Array Signal[horizon earlier]+incr Average Array Signal[horizon later]
~unit/Week~|
incr Average Array Signal[horizon]=
Array Signal[horizon]-Average Array Signal[horizon]
~unit/Week~|
Block_B_array_feedback.mdl
(1.87 KiB) Downloaded 111 times
Block_A_array_cumulative.mdl
(1.72 KiB) Downloaded 100 times
Re: Simultaneous equations involving: (array element)
I think Block B contains a real circularity. If you start expanding the equations at element H2, it becomes:
Average Array Signal[h2]=Average Array Signal[h1]+incr Average Array Signal[h2]
incr Average Array Signal[h2]=Array Signal[h2]-Average Array Signal[h2]
I think something like this would work:
Average Array Signal[h1] = Array Signal[h1]
Average Array Signal[h later] = Average Array Signal[h earlier] + (Array Signal[h later]-Average Array Signal[h earlier])/tau
rob_n
Post by rob_n »
Nice! Working sample code attached.
Best regards,
Rob
Block_B_array_feedback_v4.mdl
(1.84 KiB) Downloaded 119 times
