Vensim Crashing
TommieS
Vensim Crashing
Post by TommieS »
So I have been having this problem quite a lot, and it happens when I try to make connections in the model which are quite far apart. I draw the arrow and as soon as I make it, it crashes the program. I then get this text beneath which I am not sure if it is useful but I have included it just in case. I have a MacBook Pro running on MacOS Big Sur version 11.2.1. The version of Vensim is: Vensim PLE 9.0.1 x64. The Serial number is PL9999. Let me know if there is something I can do.
Thanks very much in advance.
The copy paste of the error (had to take some of the coding out as it was too long):
Process: VensimPLE [16140]
Path: /Applications/VensimPLE.app/Contents/MacOS/VensimPLE
Identifier: com.vensim.VensimPLE
Version: 09000100 (VensimPLE 09000100)
Code Type: X86-64 (Native)
Parent Process: ??? [1]
Responsible: VensimPLE [16140]
User ID: 501
Date/Time: 2022-01-10 02:35:17.349 +0000
OS Version: macOS 11.2.1 (20D75)
Report Version: 12
Anonymous UUID: 33A1AF87-7583-6E73-DBD8-25EF02FC4A5B
Sleep/Wake UUID: 99EF9677-CADC-43AC-9FFE-22FEAB1A86F5
Time Awake Since Boot: 480000 seconds
Time Since Wake: 110000 seconds
System Integrity Protection: enabled
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x00007fbdf9af2a98
Exception Note: EXC_CORPSE_NOTIFY
Termination Signal: Segmentation fault: 11
Termination Reason: Namespace SIGNAL, Code 0xb
Terminating Process: exc handler [16140]
VM Regions Near 0x7fbdf9af2a98:
Stack 70000dea8000-70000df2a000 [ 520K] rw-/rwx SM=COW thread 3
MALLOC_TINY 7fbecb400000-7fbecb500000 [ 1024K] rw-/rwx SM=PRV
7 com.vensim.VensimPLE 0x00000001023434e0 wxEvtHandler::ProcessEvent(wxEvent&) + 96
8 com.vensim.VensimPLE 0x00000001021c7002 wxScrollHelperEvtHandler::ProcessEvent(wxEvent&) + 34
9 com.vensim.VensimPLE 0x0000000102343bfc wxEvtHandler::SafelyProcessEvent(wxEvent&) + 12
10 com.vensim.VensimPLE 0x00000001020b19c9 wxWidgetCocoaImpl::DoHandleMouseEvent(NSEvent*) + 89
11 com.vensim.VensimPLE 0x00000001020954c6 -[NSWindow(wxNSWindowSupport) WX_filterSendEvent:] + 150
12 com.vensim.VensimPLE 0x0000000102095510 -[wxNSWindow sendEvent:] + 32
13 com.apple.AppKit 0x00007fff22f6d384 -[NSApplication(NSEvent) sendEvent:] + 352
14 com.vensim.VensimPLE 0x00000001020037e2 -[wxNSApplication sendEvent:] + 98
15 com.apple.AppKit 0x00007fff23245f1e -[NSApplication _handleEvent:] + 65
16 com.apple.AppKit 0x00007fff22dd66af -[NSApplication run] + 623
17 com.vensim.VensimPLE 0x000000010208b77a wxGUIEventLoop::OSXDoRun() + 186
18 com.vensim.VensimPLE 0x0000000102321b2d wxCFEventLoop::DoRun() + 29
19 com.vensim.VensimPLE 0x000000010227253e wxEventLoopBase::Run() + 158
20 com.vensim.VensimPLE 0x00000001022440e3 wxAppConsoleBase::MainLoop() + 99
21 com.vensim.VensimPLE 0x000000010204764a wxApp::OnRun() + 26
22 com.vensim.VensimPLE 0x00000001022ac158 wxEntry(int&, wchar_t**) + 56
23 com.vensim.VensimPLE 0x000000010171bd23 main + 35
24 libdyld.dylib 0x00007fff204ea621 start + 1
Thread 1:: com.apple.NSEventThread
0 libsystem_kernel.dylib 0x00007fff2049ae7e mach_msg_trap + 10
1 libsystem_kernel.dylib 0x00007fff2049b1f0 mach_msg + 60
2 com.apple.CoreFoundation 0x00007fff205c7bf7 __CFRunLoopServiceMachPort + 316
3 com.apple.CoreFoundation 0x00007fff205c62ca __CFRunLoopRun + 1315
4 com.apple.CoreFoundation 0x00007fff205c56ce CFRunLoopRunSpecific + 563
5 com.apple.AppKit 0x00007fff22f6b7c6 _NSEventThread + 124
6 libsystem_pthread.dylib 0x00007fff204cf950 _pthread_start + 224
7 libsystem_pthread.dylib 0x00007fff204cb47b thread_start + 15
Thread 2:
0 libsystem_kernel.dylib 0x00007fff2049d8e2 __psynch_cvwait + 10
1 libsystem_pthread.dylib 0x00007fff204cfe6f _pthread_cond_wait + 1254
2 com.vensim.VensimPLE 0x000000010159c29e vensim_event_wait + 302
3 com.vensim.VensimPLE 0x0000000101596705 execute_in_new_thread_worker_function + 277
4 libsystem_pthread.dylib 0x00007fff204cf950 _pthread_start + 224
5 libsystem_pthread.dylib 0x00007fff204cb47b thread_start + 15
Thread 3:: com.apple.CFSocket.private
0 libsystem_kernel.dylib 0x00007fff204a31fe __select + 10
1 com.apple.CoreFoundation 0x00007fff205ee6c3 __CFSocketManager + 644
2 libsystem_pthread.dylib 0x00007fff204cf950 _pthread_start + 224
3 libsystem_pthread.dylib 0x00007fff204cb47b thread_start + 15
Thread 4:
0 libsystem_pthread.dylib 0x00007fff204cb458 start_wqthread + 0
Thread 5:
Thread 6:
Thread 7:
Thread 8:
Thread 0 crashed with X86 Thread State (64-bit):
rax: 0x00007fbecd324000 rbx: 0x00007ffeee7f7668 rcx: 0x00007fbecb7ac298 rdx: 0xffffffffcb8d1a00
rdi: 0x00007fbecb793f84 rsi: 0x00000000cb8d1a00 rbp: 0x00007ffeee7f4ca0 rsp: 0x00007ffeee7f4ca0
r8: 0x00000000000003ff r9: 0x00000000000007fb r10: 0x0000000000000240 r11: 0x0000000000000010
r12: 0x0000600000f5de40 r13: 0x000000000000000d r14: 0x00007fbecd0b6800 r15: 0x0000600000f5cb60
rip: 0x0000000101a349d1 rfl: 0x0000000000010202 cr2: 0x00007fbdf9af2a98
Logical CPU: 0
Error Code: 0x00000004 (no mapping for user data read)
Trap Number: 14
External Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 17
thread_create: 0
thread_set_state: 0
Calls made by this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by all processes on this machine:
task_for_pid: 349896
thread_create: 0
thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=911.7M resident=0K(0%) swapped_out_or_unallocated=911.7M(100%)
Writable regions: Total=723.3M written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=723.3M(100%)
VIRTUAL REGION
REGION TYPE SIZE COUNT (non-coalesced)
Accelerate framework 1152K 9
Activity Tracing 256K 1
CG backing stores 2880K 6
CG image 3176K 173
CG raster data 288K 36
CoreAnimation 78.8M 107
CoreGraphics 12K 2
CoreImage 32K 8
CoreUI image data 3968K 32
Foundation 36K 2
Kernel Alloc Once 8K 1
MALLOC 337.3M 63
MALLOC guard page 32K 8
MALLOC_NANO (reserved) 256.0M 1 reserved VM address space (unallocated)
STACK GUARD 56.0M 9
Stack 43.6M 9
VM_ALLOCATE 1072K 50
__CTF 759 1
__DATA 20.0M 471
__DATA_CONST 27.8M 303
__DATA_DIRTY 1729K 207
__FONT_DATA 4K 1
__LINKEDIT 497.0M 7
__OBJC_RO 60.6M 1
__OBJC_RW 2449K 2
__TEXT 414.8M 474
__UNICODE 588K 1
mapped file 329.9M 46
shared memory 40K 4
TOTAL 2.1G 2035
TOTAL, minus reserved VM space 1.8G 2035
Model: MacBookPro12,1, BootROM 426.0.0.0.0, 2 processors, Dual-Core Intel Core i5, 2.7 GHz, 8 GB, SMC 2.28f7
Graphics: kHW_IntelIris6100Item, Intel Iris Graphics 6100, spdisplays_builtin
Memory Module: BANK 0/DIMM0, 4 GB, DDR3, 1867 MHz, 0x80AD, 0x483943434E4E4E424C54414C41522D4E5544
Memory Module: BANK 1/DIMM0, 4 GB, DDR3, 1867 MHz, 0x80AD, 0x483943434E4E4E424C54414C41522D4E5544
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x133), Broadcom BCM43xx 1.0 (7.77.111.1 AirPortDriverBrcmNIC-1675.1)
Bluetooth: Version 8.0.3d9, 3 services, 27 devices, 1 incoming serial ports
Network Service: Wi-Fi, AirPort, en0
Serial ATA Device: APPLE SSD SM0128G, 121.33 GB
USB Device: USB 3.0 Bus
USB Device: Bluetooth USB Host Controller
Thunderbolt Bus: MacBook Pro, Apple Inc., 27.1
Re: Vensim Crashing
You could try upgrading to the latest version of Vensim.
Also, can you share the model that is causing this? I've tried in PLE (9.1.0) and had no problems.
TommieS
Re: Vensim Crashing
Post by TommieS »
Of course, I'll post the model. I will also try updating to see if this helps.
Thank you very much!
ECON PROJECT.mdl
(12.03 KiB) Downloaded 103 times
Re: Vensim Crashing
What parameters are you connecting that results in the crash? I've experimented and had no problems.
