I am using the Delay Conveyor function and I would like to calculate the number of items in the delay and the leaking flow at the same time.
I transformed the instruction that are in the VENSIM HELP into a MACRO. It works , I can see the Outarg info but I am not able to use them as variable.
How can I do that ?
Access to Macro outarg
The attached model uses two output arguments from a macro.
It can be a little confusing as the macro output arguments do not appear as model variables (but they do exist).
Let us know if this works for you.
- macro.mdl
- (1.54 KiB) Downloaded 374 times
