Dear Colleagues:
I am a new learner in SD. I found SD as very interesting subject which is good
to represent mental model and mental simulation so that it easier to
communicate with others. It helps presenting and structuring all information
and factors in a quantitative way. However, I have some questions that anyone
may help me:
- How to calibrate the parameter of the model. Is that by trial error or it
has
guideline such as maximum likelihood?
- How do we represent it in the model if the data is not perfectly correlated.
Say, based on empirical data, the cofficient of correlation is 0.45 or -0.65.
- How do we represent the variation and distribution in causal-loop diagram,
instead of using average?
- How do we be so sure that the structure of the model we develop is the
correct
one? Sometimes we do not even know whether there is a relationship between one
factor to another. How do I know that this structure is wrong, something is
missing, or one or two relationship has reverse direction?
- If we can calibrate the parameter of one or two relationship, how do we
be so
sure that in the overall structure, that parameter will work?
Of course, above questions based on my assumption that there is a critical
true
parameter of every structure.
regards,
Kardi
Kardi Teknomo
Traffic Engineering and Transportation Planning Laboratory
Petra Christian University
Jl. Siwalankerto 121-131 Surabaya Indonesia
Phone: +62-31-843-9040 Local 1326
Fac. : +62-31-843-6418
e-mail: kardi@peter.petra.ac.id
Parameter of the model
Kardi,
Over the past 12 months Ive discovered that there are 3 essential
readings in SD which will answer most, if not all, of your questions.
These are:-
Randers J. ed. "Elements of the System Dynamics Method",
Forrester J.W. "Industrial Dynamics"
(These two are now available from Productivity Press)
and,
Legasto A.A., Forrester J.W. and Lyneis J.M., eds. "System Dynamics"
1980, TIMS Studies in Management Sciences, Vol. 14, North-Holland
Publishing, New York. As far as I know this book is now out of print.
If anyone else knows differently I would like to hear about it.
A number of articles in "The System Dynamics Review" also cover your
questions. If you need references I can supply them.
Bruce Campbell
Macquarie University 2109
Australia
Ph: +61 2 9850 9107
Fax: +61 2 9850 9102
These are:-
and,
Bruce Campbell
Australia
Ph: +61 2 9850 9107
Id highly recommend looking at:
Graham, Alan K. 1980. Parameter estimation in system dynamics modeling. In
J. Randers. Ed. Elements of System Dynamics Method. Cambridge, MA: MIT Press.
Khalid Saeed
_____________________________________
Khalid Saeed
Professor and Department Head
Social Science and Policy Studies
W. P. I., 100 Institute Road
Worcester, MA 01609, USA
Ph: 508-831-5563; fax: 508-831-5896
http://www.wpi.edu/Academics/Depts/SSPS/
Khalid Saeed
Khalid Saeed
