IS-LM model or a like macroeconomic models
Posted: Fri Apr 17, 1998 9:57 am
by Branko Grcic
Hello everyone
I am interested in economic system-dynamics models.
If anyone is
involved in this work, specialy if you know something about system-dynamic
aproach in construction IS-LM or a like macroeconomic models, or if any
references in this regard are known, I would
greatly appreciate it if someone could notify me. Thanx in advance.
Best wishes
Branko Grcic
Faculty of Economics Split
CROATIA
Posted: Fri Apr 17, 1998 3:54 pm
by Javier Dolado
Hello Branko,
I worked with the *basic* IS-LM model in these works
- J.J. Dolado, Qualitative Simulation and System Dynamics, System Dynamic=
s
Review 8 (n. 1, Winter 1992):55-81
- J.J. Dolado, Loop Analysis for Qualitative Simulation, Decision Support
Systems and Qualitative Reasoning, M.G.
Singh and L. Trav=E9-Massuy=E8s (Eds.), North-Holland, 1991. (Proc. o=
f the
IMACS Workshop on QR, Toulouse, France,
13-15 March 1991), ISBN 0 444 89179 X
I can send you a reprint.
Regards
Javier Dolado
Posted: Tue Nov 17, 1998 10:18 am
by "Nathan B. Forrester"
Branko,
For my 1982 dissertation I built and analyzed a simple macroeconomic model
that integrates four basic economic approaches: IS-LM, aggregate
supply-aggregate demand, multiplier-accelerator, and permanent income
hypothesis. The resulting model has ten stocks. I used the model to test the
efficacy of different economic stabilization policies. The dissertation also
points to methods, subsequently developed in detail, that allow measurement of
the relative contribution of different feedback loops to particular modes of
behavior.
You can read the dissertation abstract at:
http://www.forresterconsulting.com/Dissertation.html
MIT document services sells copies of the work:
http://theses.mit.edu
Model listings (original DYNAMO version and Vensim versions) are
available at:
http://www.forresterconsulting.com/models.html
If you have any questions, please send me an e-mail.
Nathan
Nathan B. Forrester, Ph.D.
Forrester Consulting
2687 Ridge Valley Road
Atlanta, GA 30327
Phone: 404-367-9630
Fax: 404-367-9633
mailto:NathanForrester@alum.mit.edu
Posted: Tue Nov 17, 1998 10:50 am
by "Michael J. Radzicki, Ph.D."
Branko:
Nathan Forresters dissertation titled: "A Dynamic Synthesis of Basic
Macroeconomic Theory: Implications for Stabilization Policy Analysis"
(available from MIT) presents the IS-LM model (extended through aggregate
supply and demand) via system dynamics. Also, I have created a series of
increasingly complex system dynamics models that build the basic IS-LM
framework in a manner similar to, but somewhat different from, Nathans
work. Contact me outside this mailing list if youd like me to send you the
files.
Peace.
Mike Radzicki
Worcester Polytechnic Institute
mjradz@wpi.edu
Posted: Mon Nov 23, 1998 10:29 am
by Tom Fiddaman
A copy of Nathan Forresters dissertation model, mentioned by Mike
Radzicki, can be found in my model library at:
http://home.earthlink.net/~tomfid/models/models.html
Look for the listing:
Dynamic Synthesis of Macroeconomic Theory
Provided by Nathan Forrester See: Forrester, N.B. (1982) A Dynamic
Synthesis of Basic Macroeconomic Theory:
Implications for Stabilization Policy Analysis. PhD Dissertation, MIT
Sloan School of Management.
The library contains a number of SD classics, including several other
economic models.
Thomas Fiddaman, Ph.D.
