>[Hosts note: Many MIT theses are available at
http://theses.mit.edu ]
The trick at the MIT theses site is finding things. Searching for terms
like "system" and "dynamics" is unhelpful. You might try some of the
following authors:
- Bent Bakken
- Ernst Diehl
- Rogelio Oliva
- Anjali Sastry
- David Ford
- Nathan Forrester
- James Hines
- John Sterman
- Henry Taylor
- Christian Kampmann
- Daniel Kim
- Nelson Repenning
- John Morecroft
- Mark Paich
- Peter Senge
- David Peterson
- Bob Eberlein
- Alan Graham
- Tom Fiddaman*
*You can get my dissertation from MIT as above or in one piece from my web
site (below).
These are just the dissertations that jump to mind or sit on my bookshelf
and which are recent enough to have been scanned by MIT libraries. If you
see an omission, or theres a better list somewhere, or you know where to
find the equivalent for SUNY Albany etc., Id appreciate knowing about it.
Thomas Fiddaman, Ph.D.
Ventana Systems
http://www.vensim.com
