problem in the exercise 6 of the tutorial
In the exercise 6 when one right clicks on actual consumption rate or desired consumption rate and one choses line chart, it works ok, but if one right clicks on the line chart itself it générâtes an error.
It works correctly for the other variables.
Joined the error report copied from the clipboard as word document.
There is another difference between the help tutorial and the line chart of the actual consumption rate.
In the Ventity model, the cows13 and 14 do not appear as zero on the line chart, which sounds logical as their referenced pasture does not exist and there is no available consumption possible to calculate.
erreurex6.docx
(5.56 KiB) Downloaded 293 times
Re: problem in the exercise 6 of the tutorial
Thanks ... I'll check it out.
