I have a question regarding use of an external data source. You will find attached a model where I used both the internal and the external data source, which give identical simulation results. My question goes towards the input of a table function. I used the format indicated in the table (X1,Y1),...,(Xn,Yn), which seemed to work properly.
However, how could I do this in a more automatised version, instead of doing it manually?
Include external data source
- CHD diagnosis test model1.zip
- (19.4 KiB) Downloaded 331 times
Re: Include external data source
I can see the model, but the CHD diagnosis test model1.xlsx file is missing from the archive.
Just to be clear: you want to automate providing a different lookup shape for each entity, via the input data?
Yes, that is what I would like to have. I just upload the file.
- CHD diagnosis test model1.xlsx
- (13.13 KiB) Downloaded 322 times
It looks like there's a bug that prevents reading the lookups from the initialization data - I've put in a ticket for that.
