Cant change dataset in run control
Posted: Thu Feb 16, 2017 11:40 pm
by RogerD
Just working through the basic tutorial
In Run Control
I cant change the "entry initialization data", always reverts to "use active dataset".
Re: Cant change dataset in run control
Posted: Fri Feb 17, 2017 12:04 am
Does your data selection look something like this?
- dataSelect.png (37 KiB) Viewed 4063 times
Be sure to click outside the panel after making selections; if you hit <Esc> it will revert to the previous setup.
Posted: Thu Mar 09, 2017 10:12 am
by gsimpso4
I am experiencing this problem too - and clicking outside the window doesn't work.
(I am running Windows 10 64 bit, have installed version 1.01, but the About screen says I am running 1.0.)
Trying various things - ctl-enter etc, I notice that if I hit the "Windows" key, then return to Ventity, it works.
Posted: Thu Mar 09, 2017 3:07 pm
Sorry about that - I've seen the bug, but thought it was fixed in 1.0.1. We'll get a release out ASAP.
