change properties of button
Posted: Thu Mar 01, 2018 4:06 pm
by MKui
If I edit a button e.g. change color of text or change color of button Ventity stucks which means it doesn't react on anything. I have to shut down the computer to exit Ventity and all editions are not saved.
Re: change properties of button
Posted: Thu Mar 01, 2018 4:35 pm
I can't replicate this - are you using the latest version (1.2)?
Posted: Thu Mar 01, 2018 4:53 pm
by MKui
Yes v1.2
Posted: Thu Mar 01, 2018 5:34 pm
What operating system?
Can you kill ventity via the task manager instead of shutting down?
A screenshot or video would help us to diagnose this.
Is your sequence the following?
- right-click the button
- choose "Edit"
- change the BackClr or ForeClr property
- click elsewhere on the diagram, so that the properties lose focus & close
Posted: Thu Mar 01, 2018 7:05 pm
by MKui
Windows10
Via the task manager using option 'sign off'
Sequence:
- right click
- choose edit
- change BackClr of ForeClr property
Now Ventity sticks, no possibility to do anything. Clicking elsewere on diagram, or all other possible Ventiuty options do nothing.
Posted: Thu Mar 01, 2018 7:53 pm
What happens if you use "end task"?
Posted: Fri Mar 02, 2018 9:10 am
by MKui
With 'end task' Ventity is closed.
It also appears when I select ForeClr I cannot select a color allready after the subwindow with the possible colors to select opens Ventity stucks
Posted: Fri Mar 02, 2018 4:46 pm
So if you "end task" does that avoid the need to sign off?
Posted: Sat Mar 03, 2018 10:58 am
by MKui
yes it does.
