Rabbits by color - help example
I have tried to recreate an example from the manual - access to rabbit by color. I have set references, but where I have expected values for e.g. white rabbits only, I am getting results for all color. Setting the value "white" in the reference value to match gives all colors. What am I missing?
- Rabbit.zip
- (10.5 KiB) Downloaded 345 times
Re: Rabbits by color - help example
When you plot the referenced variable, you're seeing all entities that are active in the Picker. However, if you create a variable in the Farmer that relies on the referenced "white" value, it will use the correct single entity.
- Vensim version: Ventity
Hi, I have a related question: is it possible to create plots that only show rabbits of one color e.g. white rabbits, without having to use the entity picker?
At the moment, I don't think so. I'll see if I can think of a workaround.
