Rabbits by color - help example
Posted: Sat Mar 02, 2019 10:58 am
by dproch
I have tried to recreate an example from the manual - access to rabbit by color. I have set references, but where I have expected values for e.g. white rabbits only, I am getting results for all color. Setting the value "white" in the reference value to match gives all colors. What am I missing?
Re: Rabbits by color - help example
Posted: Tue Mar 19, 2019 11:32 pm
When you plot the referenced variable, you're seeing all entities that are active in the Picker. However, if you create a variable in the Farmer that relies on the referenced "white" value, it will use the correct single entity.
Posted: Thu Aug 01, 2019 8:19 am
by barbaralaa
Hi, I have a related question: is it possible to create plots that only show rabbits of one color e.g. white rabbits, without having to use the entity picker?
Posted: Tue Aug 06, 2019 8:27 pm
At the moment, I don't think so. I'll see if I can think of a workaround.
