Print or display *.cin file
Moderator: Administrator
amehmood
Post by amehmood »
Is there any command to displany a *.cin file. I am trying to find how user can keep record of changes in the parameters. One solution has been suggested is to use Compare Run option. There miight be other ways like using *.cin file but I couldn't find any option to display or print *.cin file. Any suggestion.
Thanks,
Arif
There is no way to do it at present. A user can in theory apply up to twelve CIN files, each can have constants that overwrite earlier versions in CIN files, so implementing something like this can be tricky.
If you have a hard coded CIN file name, you could create a button to launch notepad to edit that CIN file.
amehmood
Post by amehmood »
Thanks Tony,
Could I ask what is the command for launching Notepad to edit a CIN file??
Arif
