subscript equivalence
jvalant
Post by jvalant »
I’m using version 5.7 of the software.
I have set up and equivalence (Drug,toDrug) and I have a variable called switch grid which is arrayed by two subscripts Drug, and its equivalence toDrug. When I sum across or down I get the expected answer. However, when I multiply this variable by any constant I get "0" for the answer across all dimensions. Also, when I normalize this variable in another variable I also get "0" values in each subscripted output. Any idea as to what is causing this?
Can you post a sample model?
jvalant
Post by jvalant »
Yes
experiment.mdl
(2.2 KiB) Downloaded 339 times
Try the attached model. Just needed to change some of the equations so that they had both [drug,todrug] instead of [drug,drug].
For example,
switch grid numbers[drug,todrug] = CONSTANT*SWITCH GRID[drug,drug]
was being calculated as
switch grid numbers[A,todrug] = CONSTANT*SWITCH GRID[A,A]
switch grid numbers[B,todrug] = CONSTANT*SWITCH GRID[B,B]
switch grid numbers[C,todrug] = CONSTANT*SWITCH GRID[C,C]
You need to include todrug on the right hand side of the equation to pick up the correct subscripts.
Hope this makes sense.
[Edited on 17-10-2007 by Administrator]
experiment_01.mdl
(2.21 KiB) Downloaded 315 times
jvalant
Post by jvalant »
Thanks for your help!
