Changing views in synthesim
Hi everybody
I have a slight problem.
If I have a model with multiple views, when I run the synthesim, I cannot go to another view while still staying in synthesim mode.
It is interesting for instance if you have a view with a
portion of the sketch replicated to analyze better how it works and in the course of synthesim you want to look at other parts of the model to see the result of synthesim on other variables.
You are obliged to stay on the view where you started
synthesim.
Do I make something wrong?
There is a wile that permits to switch between views.
The solution is to display a graph while in synthesim and to close it again. Then surprisingly you can switch between views while in synthesim mode. Something must be wrong somewhere or I am not using synthesim not properly.
Lee Jones
Post by Lee Jones »
Hi JJ,
in Synthesim mode, the name of the view disappears from the status bar at the bottom of the screen, but you are able to switch between views by using the page up and page down keys on your keyboard. If this does not work for you let me know.
Regards
Lee
Changing view
Hi Lee
Thank you for your reply.
It works. The former solution, displaying a graph and closing it makes the view appear again at the bottom and makes it possible to switch views. this is why it worked too.
Thanks again.
