strange behaviour in a model
Here is joined a model, that works with the subscript subs equal to s1 or s2 but does not work with subscript equal to
s1,s2. It reproduces the example of the find zero in the documentation that works, then tries to use it with subscripted variables that work with one value for the subscript but not for more?
Any idea?
find zero tracing_3.mdl
(1.99 KiB) Downloaded 264 times
There is a problem with the way FIND ZERO interacts with subscripts - though I thought it was a different problem than the one you are demonstrating. I will look into this and see if I can find a workaround.
strange delay
Hi Bob
Thank you for the answer.
