Double precision vendll32.dll
dmoraschi
Post by dmoraschi »
Hi all,
I am trying to start a simulation from Excel:
retval& = vensim_command("SPECIAL>LOADMODEL|D:\source code\Vensim\name_of_model.vpm")
If retval& = 0 Then Exit Sub
retval& = vensim_command("MENU>SYNTHESIM|O")
retval& = vensim_command("SYNTHESIM>AUTO|0")
The model must be run with the double precision DSS, but when I run it from Excel it runs in the single precision DSS. How can I tell from VB to start the double precision simulation?
Thanks,
Davide Moraschi
Have you edited the function call declarations to call into the double precision dll?
Replace "vendll32.dll" with "vdpdll32.dll" and it should work.
dmoraschi
Post by dmoraschi »
Yes it WORKS!
Thanks a lot.
Davide Moraschi
