Hi all,
I am trying to study how to run a simulation from a java application. But the example in Vensim directory does not work correctly when I am using full dll (if I use minimal dll it works).
The problem is that sometimes, when I use full dll, I get Vensim message (title: “Stop from Vensim”; Warning: “open the file C:\... using the Vensim Model Reader.”) when I am loading the model.
When I republish the model I can load it and the simulation works properly. Any ideas how to correct the problem?
-Pasi
Java + full dll problem
I've exactly same problem than priihima has, but I'm developing in the .NET-environment. I've installed in my machine Vensim PLE and Vensim Model Reader, 'cos I wasn't sure that which one I need to get VenDLL32.dll installed. And I'm using 5.7a version. Do I need to have DSS to get rid of this problem?
[Edited on 6-24-2008 by vensim.net]
Thank you for your reply.
Actually I've the same problem even with a vpm-file published from Vensim DSS. I am developing Web Service with .NET and Web Service is using Vensim DLL (VenDLL32.dll). Web Service is working fine for a while when we make vpm-file, but after a while the vpm-file stops working and vensim.err -log is telling "STOP: open the file ... using the Vensim Model Reader." After making vpm-file again, everything works fine for a while. Is Vensim DSS still the answer?
