can't switch views
Steve Taff
can't switch views
Post by Steve Taff »
Anybody have a problem like this?
My model runs fine, but when I switch to view as text, Vensim blows up. I restart, load the model, Reform and Clean: then I can switch views. But when I exit, with or without a formal save, and restart, I'm back to the blowup when I go to text.
Seems like the Reform and Clean isn't sticking across saves. Same model on another machine has same problem; same model on yet another machine does NOT have the problem.
Vensim Pro Windows 5.7a, XP SP3.
Thanks in advance.
Steven J. Taff
Department of Applied Economics
University of Minnesota
Hi Steve,
If the model is saved as a .mdl file then the Reform/Clean should not have much effect. If the file is a .vmf file then it is true that unless you do a Save after a Reform/Clean no changes are made to the saved model.
From your description I am guessing that there is something being set by a normal model read that is being reset in Reform/Clean - if you want to send me the model I would be happy to take a look to see if I can reproduce the problem.
Steve Taff
On further checking, I get a Vensim popup saying "format group control", then that gets smashed by the Windows "Vensim family of products has encountered a problem and needs to close. We are sorry for the inconvenience".
Appreciate the offer to take a peek. I'll send it to you direct. Thanks.
Steven J. Taff
Thanks for sending the model across. I was not able to replicate the problem with your model but I did receive another model that seems to do the same. That I can fix, so hopefully you will no longer have this problem with the next release of Vensim (soon).
Steve Taff
Thanks. New version soon. I'll watch for it.
Steven J. Taff
