detailed graph with subscripts
julius2905
Post by julius2905 »
Dear All,
I build a model with two subscript dimensions. Using the handson graph button the graphs of stocks and flows were displayed for each subscript value. So there were lots of behaviors to see. And it was like everyone knows.
Than I made some minor augmentations and added some new variables, but from this point the handson graph shows only the first type of the subscript, e.g. the behavior of a1 and missing a2, b3, etc. I can display every subsript type in a custom made graph if I add all subscript types in detail. So variable[subscript] does not work anymore. Does anyone has an idea, what I did wrong and how I can correct this?
Thank you in advance
Lars
Use the subscript control to select the subscripts that you want to appear in the graphs. See chapter 17 of the User's Guide or the reference Manual for discussion on this.
julius2905
Thank you very much for that quick answer. I sensed that it would something that simple. Next time I will know better.
