Model reader
Ted
Model reader
Post by Ted »
Does anyone know how to make Vensim Model Reader read models which are built in Chinese language ?
Thanks a lot
Ted
The model reader will display models in the same way they appear in the development environment as long as they use the same character encoding. Older versions of Vensim did not use UTF-8 encoding and this may be the problem. You will probably need to ask the model creator to save the model from a newer version of Vensim.
Ted
Post by Ted »
Thank you,Bob, I'll have a try by following your advice.
Ted
