cohort with SHIFT IF TRUE
Does anybody have a model that uses cohort with SHIFT IF TRUE to be used as an example? TIA.
The attached is a relatively simple demographic model demonstrating 1 year age cohorts - also it has a population pyramid graph which is useful for looking at the evolution of age distribution. (by the way dgraph is short for demographic).
- dgraph0.mdl
- (4.83 KiB) Downloaded 378 times
cohort with shift if true
Hi Bob
I tried to see how the graph on the model joined was constructed, but it seems to be a special graph that cannot be modified or viewed using the standard building graphs tool.
How is it possible to understand the building of such a graph?
programming a graph definition
Hi Bob
Thank you for the information.
I did not know that is was possible to program custom graphs!
