& character into filename and pathname
rumbao
Post by rumbao »
Dear Sir,
Our filesystem have the "&" character into filenames and folder names. When I try to open a model calling vensim_command from my C++ application and the model name or the folder name has the "&" character, vensim does not find the model to open. But when I open the model via model reader application, navigating between folders, there is no problem to open it.
My calling function is:
vensim_command("SPECIAL>LOADMODEL|c:\vensim\Projects\prueba&veras\empty.vpm")
Thank you
Jose Fornes
Have you tried something like
vensim_command("SPECIAL>LOADMODEL|c:\\vensim\\Projects\\prueba&veras\\empty.vpm")
rumbao
Post by rumbao »
Yes I tried it:
And I have the error:
Stop from Vensim
The model c:\Vensim\Projects\prueba.vmf does not exist - can´t open.
It seems to stop it reading filename when it finds & character and it adds ".vmf" at the end.
The & is used to separate Vensim commands. So Vensim is getting two command
and
veras\\empty.vpm
the second one does not make any sense but it fails on the first anyway so it never gets there.
There is not an escape sequence for & - I will take a look to see if one can be added.
rumbao
Post by rumbao »
Thank you for your answer
I will look forward an escape sequence.
Jose Fornes
Hi Jose,
This will be in the next release and done by using quotes around options as in
SPECIAL>LOADMODEL|"c:\vensim\projects\prueba&veras\empty.vpm"
so in C the command would be
vensim_command("SPECIAL>LOADMODEL|\"c:\\vensim\\Projects\\prueba&veras\\empty.vpm\"")
rumbao
Post by rumbao »
Thank you
